Creda sensadry reversair model 37751
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Creda sensadry reversair model 37751
  • #77371
    DEMPSEY1965
    Hi, first of all apologies if this subject has been discussed before. My Creda tumble dryer thermostat is on the way out. I have managed to use a pin to reset etc but I am going to need a new one or pair. Can anyone tell me the part number that I will need for both thermostats. Many thanks for your help.
    #401993
    Re: Creda sensadry reversair model 37751
    Two different kits used, full serial number required to identify. Have you checked the outlet hose and wall vent, constant tripping of stat is due to airflow obstructions,
    #401994
    DEMPSEY1965
    Hi, apologies for not getting back sooner and thanks for the reply. I will check the hose etc for blockages. The model number is 37751 if that is any help.
    #401995
    Steven
    As Jim said two types but they should be id easily!
    http://shop.ukwhitegoods.co.uk/catalogs … =C00095674
    The terminals are horizontal to the stat blue spot
    http://shop.ukwhitegoods.co.uk/catalogs … =C00209193
    The terminals are vertical to the stat see pictures.
    #401996
    DEMPSEY1965
    Thanks Steven, I have looked at the old ones and they are similar to the 2nd type as the terminals are not flat but point outwards. Do you know what the additional wires are for? Can I just replace the stats using the old wires?
    Thx
    #401997
    Steven
    yes, normally no need to use the additional cable.
    #401998
    DEMPSEY1965
    Thanks Steven, just wanted to make sure. I have also ordered a pair of new pulleys to replace my old squeaky ones. Out of interest what is the best way to go about replacing? What I mean is what panels etc to remove as I don’t want to remove stuff that is not necessary.
    Many thanks
    #401999
    DEMPSEY1965
    Hi All,
    Help! I have fitted both the stats and the heating element seems to cut out after about a minute, any ideas what this can be?
    #402000
    DEMPSEY1965
    Creda Sensadry model 37751
    Hi All,
    My Creda Reversair Sensadry fails to produce any heat so I replaced both stats as a starter. When I turned on the machine the problem still exists where the element produces heat for about 30 seconds then just dies. Any ideas what else could be the problem. I do appreciate your help.
    Regards
    DEMPSEY
    #402001
    DEMPSEY1965
    Also can you tell me which thermostat goes where as they are not similar. The one on the right has a little hole in with the terminal above and below this is coloured black and the one on the right is grey with the terminals side by side. The new kit has the terminals on both stats side by side.
