Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › creda sensorcare belt fitment
- This topic has 11 replies, 4 voices, and was last updated 19 years, 6 months ago by
dizzy1.
October 6, 2006 at 5:56 pm #21475
dizzy1
Participanthello everyone,ive got a problem with a sensorcare tumble dryer.The belt snapped and i bought a new one from our local store and thought great problem solved.how wrong was i,after fitting belt around the drum through the jockey wheels and placing the motor correctly theres not enough tension on the belt.The motor seems none adjustable as this is screwed directly to the base plate,does anyone have any experience of these and could anyone please point me in the right direction cheers dave 😳 ps im a mechanic by trade for 18 yrs but must be doing something wrong
October 6, 2006 at 6:13 pm #191046dizzy1
ParticipantRe: creda sensorcare belt fitment
by the way its a 37661 model thanks 😆
October 6, 2006 at 6:15 pm #191047pto
wrong belt ?
October 6, 2006 at 6:17 pm #191048dizzy1
no belt no is the same as listed on all info searched.ive removed both jockey wheels and placed belt through and placed motor in what seems to be correct position but still slack only by about 1 ” though
October 6, 2006 at 6:24 pm #191049pto
you dont have to remove both jockey wheels to fit a belt
October 6, 2006 at 6:27 pm #191050dizzy1
ah ha any chance of some inside info then lol as obviously the belt was snapped and cant seem to get a diagram for belt direction anywhere
October 6, 2006 at 6:31 pm #191051dizzy1
ill take im correct in fitting the belt flat side to the drum
October 6, 2006 at 6:40 pm #191052pto
You don’t fit the flat side to the drum, it’s the ribbed side to the drum.
Hope the image helps…
October 6, 2006 at 8:23 pm #191053dizzy1
pto thanks for your help its very much appreciated and ill give it a try tomorrow and like i said im a ford tech so if you got a ford car and need any help give me a shout cheers Dave
October 7, 2006 at 1:05 pm #191054dizzy1
😀 thanks for all your help.Half hour later and what seems like a hundred screws dryer all fixed and with two full time working adults and two kids in horrid weather its a god send once again pto your a star for the help many thanks Dave 😉
October 7, 2006 at 4:44 pm #191055DDSDDS
the reason for all the screws imo is that creda hav shares in a screw factory 😆
October 7, 2006 at 5:54 pm #191056iadom
ModeratorRe: creda sensorcare belt fitment
Of course if you know what you are doing, you tip it upside down, remove just seven screws, prise the front panel away and slip the belt round the drum and onto the motor pulley, making sure you route it correctly. Under 10 minutes in total. 😆
