Creda simplicity 1000
  • #33087
    triphop
    Creda simplicity 1000 problem, drum turns forwards and backwards when washing but dosn’t turn on rinse(brings the water in then stops) and dosn’t turn on spin(timer clicks away but nothing happens).
    Please help…. ❓
    #237369
    Re: Creda simplicity 1000
    Probably the motor brushes packing in. Model number would help.
    triphop
    Model numbetr 17110
    Will take the motor off and have it checked out
    All unpluged…………
    #237371
    Goatboy
    Don’t take out the car’s engine to check the oil! 8)
    Unless your phyically taking the motor somewhere to be checked over?
    #237372
    triphop
    dipstick!!!!!
    #237373
    triphop
    Thanks Penguin
    It was motor brushes, Harraps in Southampton had them on the shelf.
    Job done all back together and workin again
    Thanks again for top advice!!
    #237374
    Goatboy
    triphop wrote:dipstick!!!!!
    Sigh! Look what happens when you try to help someone πŸ™
    #237375
    Goatboy wrote:
    triphop wrote:
    dipstick!!!!!
    TouchΓ©, Paul, had you just told triphop that he/she did not need to remove the motor from the machine to check the brushes I’m sure he/she would have thanked you, as you chose an automobile analogy, referring to checking the oil I think the response was most apposite and amusing. πŸ˜†
