CREDA SIMPLICITY 37761 DRYER
Home Forums Public Support Forums Help And Support Washing Machine Help Forum CREDA SIMPLICITY 37761 DRYER
  • #18631
    tallpaul
    Dryer stopped rotating but motor humming in background. Removed drum and tried giving the motor a spin – stood back and switched on (while motor still spinning) – the motor ran ok. Tried again from standstill motor will not start. Anyone any idea what’s happening?
    #179693
    Dave_Conway
    Re: CREDA SIMPLICITY 37761 DRYER
    The capacitor has failed by the sounds of it, if you read this post:
    http://www.ukwhitegoods.co.uk/modules.p … ic&p=19933
    Scroll down to where Ade says “Hello Again !!!?” 😀 that’ll help with identifying and getting the part. Power off when checking please :zap:
    If you’re unsure, check the repairs@ link below for an engineer 🙂
    #179694
    tallpaul
    Thanks Dave, I’ve checked out the white goods shop and spotted a universal 7uf capacitor. Mine is rated as 7.5uf would it make much differnce to use a 7uf instead?
    #179695
    tallpaul wrote:Mine is rated as 7.5uf would it make much differnce to use a 7uf instead?
    Not really, this is a better option. 😉
    #179696
    tallpaul
    Thanks Martin.
