creda simplicity dryer tvr2
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum creda simplicity dryer tvr2
  • #63033
    matty_butch
    I have a creda simplicity dryer tvr2! Which iv had for a year! The drum has stopped spinning and also dropped at the back!! Anyone have any suggestion on how i can fix it? Also what part I need to do so?
    #352281
    gandh1
    Re: creda simplicity dryer tvr2
    buy this
    http://shop.ukwhitegoods.co.uk/Tumble+D … g+Kit.html
    and this (if the belt has dissapeared from the drum)
    http://shop.ukwhitegoods.co.uk/Tumble+D … +Belt.html
    hotpoint bearing kits used to have vague instructions included.
    youll need philips s/driver, possibly rivetting tool, and a 18″+ long screwdriver/strong peice of V-section metal strip to act as a belt puller.
    PLUG OUT FIRST before doing anything to machine or you will get a :eeek:
    there is absolutely no need to have any electricity in the machine during the whole of this job
    TIPS:
    ive always found access easiest by removing lid, then LHS panel (the side the vent is on). theres lots of hidden screws, so if it doesnt feel like its going to move, dont force it. you will need to take off the fascia panel. there are 2screws holding it screwed from the inside, rhs iirc and plastic catches on lower long edge. this then allows acces to top front screw holding side panel on.
    always check front pads, if one of bottom 2x is paper thin, replace all of them. and have some 1/2″ self tapping pan head screws spare as a couple of ~TVR2s ive worked on seem to have had screws missing from new, hastening body flex and belt snappage… ~HTH~
    #352282
    gandh1
    *EDIT* LHS when viewed from rear. oops my bad, its opposite side to the vent 😳
