CREDA Simplicity T622CW – stats fail quickly
Home Forums Public Support Forums Help And Support Washing Machine Help Forum CREDA Simplicity T622CW – stats fail quickly
  • #57774
    midi
    Guys
    CREDA Simplicity T622CW condenser dryer, approximately 6 years old
    It’s stopped heating again.
    Seems to be going through thermosats a rate of knots.
    Any ideas on what could be causing the stats to fail so quickly.
    Thanks in anticipation
    George
    #332257
    Martin114
    Re: CREDA Simplicity T622CW – stats fail quickly
    I would check the motor capacitor.
    #332258
    midi
    Thanks for the reply 😀 – how do I check it and are you able to advise where its sited. As a education ❓ – can you help me understand how it would affect the stat.
    Regards
    #332259
    midi
    Just bumping to the top in case anyone missed it
    #332260
    midi
    One last bump to top – getting grieve off the wife – link to a capcitor would be welcomed.
    Cheers
    #332261
    If the capcitor is faulty the motor will struggle to start or fail to turn at all.
    Capacitors of all shapes and sizes HERE, its located close by the motor.
    Have you checked the condenser is completely clean?
    #332262
    midi
    Thanks for the reply – I’ve had the drum full tonight with dry towels to check the motor – can here it going around and note direction – when reversed seems to do so easily and the direction of rotation has chaged, so could it still be a capacitor problem?
    The condenser was washed out a whille ago using a power washer on low pressure – so shuld still be okay.
    Air flow through the machine seems to be okay
    Confusedm all seems okay but stats fail
    #332263
    The condensor should be cleaned regularly, you should be able to see clearly through it at all times. A pressure hose on high pressure would be better. 😉
    Sometimes the timer can cause premature stat failure if it fails to allow the 10 minute cool down. Thats why the machine should always be allowed to complete the cycle fully and not stopped before the end.
    If the drum appears to be turning perfectly with a full load then the capacitor may well be OK although it can break down with use.
    #332264
    midi
    To all respodents
    Thaks for the advice guys – cleaned everything out and orderd new stats – hope it works this time,
