creda solar plus built-in double oven model no.48121
Home Forums Public Support Forums Help And Support Cooker And Oven Forum creda solar plus built-in double oven model no.48121
  • #74458
    cookerbee
    The temperature in the oven reaches an uncontrollably high level and the grill has now failed. Do I take it the thermostat needs replacing? If so, where is it situated please? Is it something my partner or I could replace? We are both quite handy and I can’t interest an electrician in the work. Incidentally, we haven’t been able to budge the oven from its housing.In fact will we need to and any tips as to how best to get at it if we do?!I understand we should firstly turn off all the electricity connected!
    #391668
    cookerbee
    Re: creda solar plus built-in double oven model no.48121
    Failed thermostat: the oven reaches uncontrollably high temperatures and the grill has now failed.
    #391669
    TBH you don’t need an electrician as such but someone with experience of repairing domestic appliances.
    You need to be able have suitable electrical test equipment and know how to use it to test the grill components and ensure the machine is safe after repair as well.
    Changing the thermostat on this machine is not really a simple DIY Job. My advice would be to use the ‘Find an engineer’ link at the top of our home page.
    #391670
    cookerbee
    Thank you : sounds good advice
