Creda Solar Plus – Main Oven Won’t Heat Up
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda Solar Plus – Main Oven Won’t Heat Up
  • #70111
    TheRambler
    Because the main oven wouldn’t heat up I replaced the heating element, but even with the new element it still doesn’t heat up.
    My first reaction is to replace the selector switch, but before I do that
    A)I’d like to know if there’s anything else I should check first?
    B)It doesn’t look like an easy job, has anyone got any info on how to access it?
    Any help you can provide would be appreciated.
    Cheers
    #377033
    Re: Creda Solar Plus – Main Oven Won’t Heat Up
    Thermostat?
    A model number might help though as there’s more than a few in that range.
    Does the main oven fan run, did you test the old element before you changed it?
    As mentioned above, model number is an absolute must.
    #377035
    TheRambler
    Thanks for the rapid response guys.
    The model No. is: 48337
    Serial No. 95100056
    Main oven fan runs ok but no heat. Also the red light does not come on at the selector switch.
    If its the thermostat where is it located?
    Cheers
    #377036
    So, did you actually test the old element first before you changed it?
    The thermostat is behind the oven control knob.
    Not a simple DIY job and as it is around £60.00 I would suggest that if you don’t have the means to properly test electrical components then get someone who does to have a look at it first.
    It’s both sides off, complete hob lift, plus quite a bit of other work involved.
    #377037
    TheRambler
    Thanks iadom,
    As its done a fair bit of work I assumed that it was the element, I’ve had that on other ovens before. At least I’ve got a spare element should it fail.
    Thanks for your help.
    Cheers
    #377038
    Its wise never to assume anything, proper testing with the correct equipment is the only way to avoid expensive mistakes. 😉
