Creda Solarglo 48331 Standalone main oven fan replacement
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda Solarglo 48331 Standalone main oven fan replacement
  • #55246
    jb-1969
    Replacing the fan in the above standalone oven.
    You would think Creda would have a “4 screw removable panel” around the fan to ease its removal… oh no.
    – The rear panel is retained under the side panels AND the hob panel.
    – Thus far I have removed the side screws & top hob screws.
    – The side panels are not sliding off at the top because they slide under the hob panel, which I am wary of lifting further without first checking.
    Anything else to do or know about to get the rear panel off?
    Already have the part, just wary on a 14yr old cooker (yes cooker isolated, RCBO padlocked off). Built-in cookers are way easier to work on (and lighter too).
    Thanks.
    #322409
    jb-1969
    Re: Creda Solarglo 48331 Standalone main oven fan replacemen
    First problem fixed.
    The hob & sides only need be lifted 0.25″ to lift the back panel off.
    New problem.
    The old fan fits through a shaft-sized hole in the oven chassis, and will obviously not slide off with the circlip & washer attached to it.
    You have to use circlip pliers to remove the circlip & washer, then slide it out of the oven.
    Hilariously the new fan employs a circlip and washer, only the washer is bizarrely has been press fitted and will require a puller or cutter to get it off.
    It makes me think the latter ovens have a large hole – clearance for the washer/circlip assembly rather than just the shaft as mine has.
    I have never seen so much dust in an appliance, not even multi-decade old TVs. Cleaned the top fan.
    Now to cut that washer off.
    Bagging & taping the rest so no filings get near it. My puller is too large for such a tiny item.
    #322410
    jb-1969
    Done, fitted, working.
    Not an easy job, but a whole lot quieter.
    Took a long time to get all the fluff out, which appears to have been shed in a blanket from the upper fan.
