Dishwasher programme has just stopped working. If I set the dial it won’t progress and is stuck in that position. There is power and the machine will do what ever the dial position should be doing. If I turn the dial again it is stuck in the new position. I have tried tilting the machine forwards and backwards by 45 degrees – no change. I’ve unplugged the machine for 30 minutes – no change. The only difference is that now the machine leaks a little.
As this is an old machine is there anything else I can try or is it time to bite the bullet and get a new machine?
