creda t/d 37643
  • #8613
    does anyone have a diagram to show where the wires on the timer go for this model please.
    save me
    thanks
    #129609
    recall
    Re: creda t/d 37643
    whats the manufacturer of the timer youve got…
    #129610
    Re: creda t/d 37643
    its an eaton timer
    #129611
    recall
    Re: creda t/d 37643
    hi
    is it the zbn or the jk model??
    jk6011 connections
    red/bla -motor:19
    bro/bla- motor:17
    blu – motor:1
    pin/whi – door:3
    bla/whi – cycle stat:9
    i think theres a link from 15-23 could be internal tho
    if struggling still have got convert leaflet in office 2mora…..
    #129612
    recall
    Re: creda t/d 37643
    sorry found the zbn connections
    this is using prev numbers in jk post to zbn timer
    ie 9 cycle stat is 10 on zbn and so on so
    9 now 10
    3 now 2
    1 now 8
    17 now 5
    19 now 3
    😯 any use????
    #129613
    Re: creda t/d 37643
    what is zbn or jk is that the number on the timer its eaton, the first set of numbers and colours you gave matches with what ive got so i presume it must be the one i need.
    #129614
    Re: creda t/d 37643
    i have been back and put the wires back on where you said and it worked
    a treat so thanks a lot vey much appreiated
    #129615
    recall
    Re: creda t/d 37643
    as far as im aware the jk or zbn is just the timer identifier, it should be stamped on the timer somewhere…
    glad to help… 😀
