Creda T322VW can i retrofit with belt and pulleys?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Creda T322VW can i retrofit with belt and pulleys?
  • #13033
    Simon46
    My own 3kg tumble dryer is starting to get noisy. Can i put nonstretch belt and pulley on it to make it last?
    Regards
    S.
    #152747
    Dave_Conway
    Re: Creda T322VW can i retrofit with belt and pulleys?
    I don’t know but using the drum part number as a cross reference tool and a simlar chassis I reckon you’ll need belt part number 208081 and two pulleys 1740944.
    Don’t blame me if it’s wrong though 😉
    #152748
    Simon46
    The slits are there for pulleys. Will need spring too. Thanks Dave will give it a go.
    S.
    #152749
    Dave_Conway
    Simon46 wrote: Will need spring too.
    1740129 🙂
    #152750
    bobokines
    Surely that belt number is for an early 5KG model!
    Bob
    #152751
    Dave_Conway
    It is Bob, you’re right.
    Although the same drum is fitted to the full capacity dryer 😕
    Simon, try 1741117 instead 😳
