hi guys need a bit of advice cust reporting on phone that is overheating and could smell burning, i asked if it did cut out eventually and its not, can i confirm that changing all 3 stats would render this machine then safe to use? 😕
It’s just the regular C00095674 (2 stat) kit you need. Probably the burning smell is the usual build-up of fluff in the heater ducting. So a good vac clean might be the order of the day here?:wink:
