creda t601cw condenser dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum creda t601cw condenser dryer
  • #6989
    nella
    Hi, can anyone help with a problem relating to this model of dryer:
    The machine is not heating up but drum spins etc. Been fixed before and new thermostats fitted which could be reset with pin. However it doesn’t reset anymore!
    Could this mean heating element needs replaced and/or thermostat??
    If so, is this an easy task or will i need an engineer?
    Any replies gratefully accepted
    #120776
    Dave_Conway
    Re: creda t601cw condenser dryer
    It’s nearly always the thermostats nella and sometimes but more rarely the element.
    Neither are hugely expensive and a simple enough job for an engineer so not too labour intensive either.
    Pop your postcode up and someone should be able to help further with a service visit for you.
