Allowed myself 15 mins to pop the usual stat kit on one of these the other day.. as you do, but no, diagnosis incorrect. No power at heater/stats, above door stat is closed circ, very low volts detected at water float sw while live testing.
Ran out of time at this point,forgot to check if machine stuck in reverse, any common timer heat faults on this machine? Thanks.
