Creda T601CW Not Heating – any advice?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Creda T601CW Not Heating – any advice?
  • #6703
    Hi there,
    Our Creda T601CW dryer recently stopped heating (drum still spins, fans still run etc) – we’ve cleaned out all the seals, filters and emptied the water etc.
    I’m guessing the thermostat or heating element has expired, and we’ll need a service call but I thought I’d check if there’s actually a simple solution to the problem?
    Any help/advice would be very much appreciated. Cheers, Tom.
    #119115
    tonyclifton
    Blocked
    Re: Creda T601CW Not Heating – any advice?
    Sounds like thermostat fault check that 1st
    if doing self dont forget to plug out plug 1st 😉
    if not look in directories for engineer near u
    Regards
    Tony
    #119116
    philfish
    if it is the condensor sort usually there is 2 thermostats on top of the element only one usually goes but change both because when one goes usually makes the other one weaker remember pull the plug and if in any doubt get an engineer 😉
    #119117
    Thanks very much for the help people, would changing the thermostats be a complicated job? I know a little about electronics but don’t wanna be messing around with anything that could go really wrong. Where could I get hold of replacements?
    We would call out an engineer but were quoted £100 for the call-out & repair, think we’d rather get a new dryer. However if I can fix it myself, that’d be the best.
    #119118
    Dave_Conway
    The thermostats are quite straightforwaard to change, just remove the rear panel of the dryer, they are right there on top of the heating element.
    The thermostat kit (2 in a pack) is part number 1701583, available from our shop here:
    http://shop.ukwhitegoods.co.uk/c0009556 … mostat-kit
    #119119
    Dave, thanks a lot for that, gotta be worth a go I think. How long does delivery take on that item? Domestic life is falling apart without a working dryer!
    #119120
    Dave_Conway
    I’ll send them 1st class today if you place the order as soon as you can.
    #119121
    Thanks again Dave, I’ve placed the order now.
    #119122
    Dave_Conway
    Got it thanks 😀
    It may be a little late to get out today now, you should recieve by Saturday at the latest though.
    #119123
    I’d just like to thank Dave, Phil and Tony for your help, got the parts this morning and fitted them, has solved the problem!
    Thanks so much, you just saved us a lot of money! Cheers.
    #119124
    Dave_Conway
    tomh4 wrote:Thanks so much, you just saved us a lot of money! Cheers.
    No problem 😀
    #119125
    multilevel
    Two and a half years later, but can I offer thanks for the existence of this thread. I had exactly this problem, but thanks to getting the thermostats mentioned and fitting them myself, the dryer works again.
    Many thanks to all concerned.
    Multilevel
