Creda T602CW Dryer
  • #21636
    johnnyhoz
    have the above dryer, it runs and heats, its suppose to cut out when the clothes are dry but it runs continuously, has anyone come across this before. Would appreciate some guidance.
    John
    #191964
    SDR
    Re: Creda T602CW Dryer
    if it has a module fixed in top rhs looking from front, replace that as it is a sensing module, check that the earthing brush is making contact or not broken. check that condenser is clear, also check that no build up of lint between door panel behind lint filter.. hope this helps .
    #191965
    johnnyj
    If you remove earthing brush from band it should come out of dry as this would indicate a high resistance, if so check the band is insulated from the drum, if it doesnt i would go for module i hope this helps you cheersjj.
