lynx2oo2 wrote:Timer, as in this one…
No! :lesson:
Your machine also incorporates a REVERSING TIMER (located in the base of the machine which operates the reverse sequence as well as the switching on and off of the heating element. (i.e. Whilst it does the short reverse cycle this timer switches off the element, then on again for the longer tumble sequence). Chances are that the Reversing Timer has switched the element supply off permanently due to stuffed contacts. 🙁
The Reversing Timer is part no: 1701133 and only available via emailing these details to spares@ukwhitegoods.co.uk
OK? 8)
