I am trying to locate the front thermostat to test it but failing miserably.
The best advice that I have found is ‘on the plastic drum surround at the front’. ‘Above door aperture’
But no luck.
Any ideas please?
As Dave says, it is on the inside upper edge of the plastic door opening surround, set at about 5 minutes to 12 o’clock. It is just possible to pull it GENTLY into the door space to access but you will need to cut off a small cable tie accessed from above with the top off the dryer. If you don’t remove this tie the wires will pull off the stat.
