CREDA T620CW
  • #18289
    PGS
    Ive been to this m/c 4 times and customer is complaining of no heat ,
    each time i call it works 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} ok, ive replaced front and rear stats cleaned condenser checked wiring, she also said that tank full light comes on when tank is empty, any ideas on this one cheers paul.
    #178465
    AMS
    Re: CREDA T620CW
    It could well be the timer, especially if it’s a Copreci as they’re cr*p. The new one is an Eaton and comes with a conversion kit and instructions.
    Hope this helps,
    Re: CREDA T620CW
    AMS wrote:It could well be the timer
    Yep! Got to agree with Dave on this, the timer contacts get all black and charred = new timer 😉
    #178467
    Bryan
    Re: CREDA T620CW
    PGS wrote: she also said that tank full light comes on when tank is empty, any ideas on this one cheers paul.
    Float chamber and/or valve gunged up ❓
    Bryan
    #178468
    bobokines
    Re: CREDA T620CW
    I agree with Bryan. Look for a blockage in the float chamber. If it’s ok when you are there and the customer has mentioned that the full tank light is comes on too early, then it’s much more likely to be float chamber problem than a timer fault
    Bob
    #178469
    Re: CREDA T620CW
    Dodgy wiring on the front stat is worth checking out.
    HotDog
    Definate float chamber fault
    #178471
    PGS
    Re: CREDA T620CW
    Float chamber was chocka block, just waiting for sealant to go off to test confident this was the fault ,Thanx guys.
