hi was called to this t/d today ,the drum is not turning but the belt is ok and tried hand starting it but no joy i know from other posts that the relay gives trouble ,but this is not cutting in and out, it just wont start is it the timer?
thanks
If you just un-hook the belt will it not start then? 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time its just the capacitor. 😀
If the capacitor is open circuit or low capacitance then the symptom would be that the drum will start with a push, however if the capacitor is short circuit then the motor will simply lock up…
