Creda T620CW Drier
  • #27353
    Rustyremi
    I just found your website and seen that a common probelm with this model of drier is the SCHRACK RM505730 Relay. When you order the part from the on-line shop will it have a diagram for connecting the wires. Reason is I took the relay out to check with a meter and wrote the contacts and wiring connections on the drum in pencil. While checking out the relay ( note the machine was unplugged, my wife decided to clean out some of the lint and dust inside and wiped out my diagram).
    #213740
    Re: Creda T620CW Drier
    Oh dear. Please refer to section 8 here. http://tinyurl.com/mq8g3
    These parts do not come with wiring diagrams unfortunately.
    Rustyremi, you have posted the same question in two separate posts at around 4.45pm & 5.58pm. This only leads to confusion when different members answer your questions, by all means bump a post but please try not to duplicate them.
    I have deleted your other post with apologies to Helo-75 who took the trouble to answer you in much the same vein as my first answer.
