Creda T620CW Not Heating
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Creda T620CW Not Heating
  • #8400
    barney11
    Problem with Creda T620CW not heating.
    I have checked both thermostats as described in earlier post on various creda’s and they seem fine(both convex).
    Any help on what to look at next and how to check it would be much appreciated.
    clyde
    Re: Creda T620CW Not Heating
    barney11 wrote:Hi
    Hi Barney :beer: :beer: :beer:
    Have u checked the stats for continuity with a multimeter? (visual check is normally ok. multimeters are a bit more accurate)
    if the stats are ok is the water full light on when in use? and is the drum definatly turning???
    Clyde
    8)
    #128443
    barney11
    Hi Clyde
    Yes, checked the continuity with meter all ok.
    The drum is turning and the empty water light is not on.
    Cheers
    clyde
    It could be the front thermostat thats failed. A few other possibilities are the heater itself, damaged wiring, or a possible timer fault.
    If you are unsure look in repairs@ for a local engineer. If you do have another look pull the plug out first :plug:
    Clyde 8)
