CREDA T622CW
  • #48297
    deej
    Hi all,
    thanks for your help previously.
    I got new capacitor, removed the top from the machine, and at the top of the casing at the front is some sort of box with wires attached ( blue red and grey) These wires then travel round to the back of the machine.
    Where they are attached to this box one of the blue/white and connector are burnt, quite badly.
    Can i replace this, and would i have to replace the ‘box’ too, what are they? I can take pictures if that helps/
    Please help once again!
    Deej 😡
    #296214
    bazza500
    Re: CREDA T622CW
    Pictures would be good 😀
    #296215
    deej
    Re: CREDA T622CW
    Ok, how do i upload pictures to the site or on PM please? Dee
    #296216
    Re: CREDA T622CW
    You need to host them somewhere like Imageshack, Photobucket, Putfile or any other web hosting site and then copy the url into your post.
    If you can upload them to your own webspace you could paste them into your post using the image tags.
    The control timer is located behind the timer knob, the relay is in a more central position, both of these have more than three wires going to them though. 😕 The relay has a ‘see through’ casing.
    Either component will be damaged and need replacing and the wiring repaired at the same time.
    deej
    Re: CREDA T622CW
    Many thanks for that, think that i’ve established that the main problem is the wiring from the relay but i may have to replace the relay too! 😕 Not sure where i will get the wiring loom from!
    #296218
    don
    Re: CREDA T622CW
    Hi deej
    I moved your question from the duplicate thread you created. It`s easier to answer in just one 😉 .
    Don 🙂
    deej wrote:I have a burned wiring loom leading from relay( clear brown box) can a new loom be purchased?
    i know i can get a new relay ❓ [][/url
    #296219
    Re: CREDA T622CW
    Its very unlikely that you will be able to get a wiring loom. It isn’t really needed.
    I, like almost all other trade members would cut back the damaged wiring and fit new cable and AMP tags using blue (not red ) butt connectors.
    #296220
    deej
    Re: CREDA T622CW
    Thanks, yes i have no problem doing that, can i get the cable and connectors from any diy store? 😕
