Creda T622cw heater element
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Creda T622cw heater element
  • #26078
    leeroypenmut
    I had a problem with my dryer blowing my house fuse, after some problems with the switches & replacing the timer it work for a few weeks, but today again it blow the house fuse, checked the heater and one coil is bent & i think it touching the other one!
    On seaching the internet there is a difference in heating elements, 2.2 & 2.5, some quote 1701768, & some the 1701584 for the creda T622RW
    Which one is correct?
    One more question, both my stats on the back the plates(little discs inside the stat) are loose but seem to work ok!
    Thanks for your help 😀
    #208690
    Re: Creda T622cw heater element
    You need to check the serial number of your machine. The first two numbers are the date code. If the serial number begins with 19 or less then you need a 1701768 2.5 kw element, if the first two numbers are 20 or above you need a 1702697 2.3 kw heater.
    Are you sure it is a T622RW, I can only see a T622CW. I wonder if it is a factory reworked machine, did you buy it from a discount shop?
    leeroypenmut
    Sorry typo T622CW, bought new from comet
    My ser no. 16105078, so its the 1701768 2.5 kw element?
    What do you think about the Thermostats?
    Are they meant to be loose?
    Thanks for your quick quick reply
    #208692
    Dave_Conway
    leeroypenmut wrote:My ser no. 16105078, so its the 1701768 2.5 kw element?
    Yep 😀 – which is here:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=359
    leeroypenmut wrote:What do you think about the Thermostats?
    Yes, they will be fine :tup:
