This one should probably be under the Relations, PITA topic.
Cousin of mine rang me up to look at his dryer. Went down today to be handed the relay.’I think this is the faulty bit, it flashes and then the drier stops’
‘Did you make a note of the wiring?’
‘Ithought you would know where they went’
‘T*t! 😡 ‘
Anyone have the wiring for the relay to hand?
I don’t have the T622CW specific wiring, will send you TDC30 & TDC60 schematics, they use the same relay so hopefully you should be able to sort it from that.
