creda t622cw slow drying Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › creda t622cw slow drying This topic has 6 replies, 3 voices, and was last updated 13 years, 7 months ago by delta01. Viewing 7 posts - 1 through 7 (of 7 total) Author Posts August 16, 2012 at 7:44 am #70976 delta01Participant hi this machine seems to do all it should but customer complains that it takes too long not had this prob b4 any suggestions appreciated thanks john August 16, 2012 at 8:11 am #379503 iadomModerator Re: creda t622cw slow drying Change the customer. 😉 Usual suspects blocked condensor, also possible high/low heat switch fault or faulty element. Have you tested it to see if the amps drop when you switch the high/low switch on and off? Jim. August 16, 2012 at 3:02 pm #379504 delta01Participant Re: creda t622cw slow drying thanks Jim will investigate your suggestions john August 16, 2012 at 3:54 pm #379505 HotDogParticipant Re: creda t622cw slow drying could be stat above door does go faulty will work intermitantly August 17, 2012 at 7:27 am #379506 delta01Participant Re: creda t622cw slow drying thanks Hotdog do you have a part no please john August 17, 2012 at 7:57 am #379507 iadomModerator Re: creda t622cw slow drying C00095536. August 18, 2012 at 5:20 pm #379508 delta01Participant Re: creda t622cw slow drying Thanks v much iadom john Author Posts Viewing 7 posts - 1 through 7 (of 7 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
