This machine, a Creda T630CW condensing tumble-dryer runs for a little while from cold and then stops. If you press start again nothing happens. If you wait a couple of minutes and press start again it will then run for a few seconds and stop again. I think it might be the relay, is that the most likely cause? If so, which is the correct replacement? Thanks for any info.
