Creda tumble drier, T632CW. Set to sensor dry and it never switches off, Heats and dries just fine but will continue heating till customer turns it off, 30 min setting works ok. Module? timer/selctor?
anything I have missed?
thanks in advance.
A short circuit from the sensor band to the drum will cause this fault, is the insulator band insulating the sensor band from the drum also check the sensor disc is insulated from the drum, if so looks like a module fault. JJ
