Re: Creda TCR2
May be worth having a quick read of this , if your machine has the pulleys at the front of the drum then this kit also includes a rear bearing, there is no mention on Partfinder of a modified rear bearing shaft.
Apparently the back panel has also been modified but should come under the original part number of 1703017, list £31.19 ex vat. It includes a thicker rear seal.
The aforementioned bearing & pulley kit is part No: 1703273, list £18.54 ex vat.
There is also a modified rear heater cover panel inc heater and stats to prevent the fan fouling the back cover, part No: 1703075, list £28.66 ex vat.
In other words if you completely rebuild this machine with all the mods, it might run with less noise. Or they could buy a decent dryer. 😥
