this condenser dryer is tripping rcd due to water getting into the fan area and spraying onto the heater, ive replaced the pump and cleaned out debris from sump, when i removed the condensing unit and put my hand to the back it was blocked in the channel that goes to the sump,
but it is still tripping the rcd???
help pls
still cant work this one out??? ive taken the base off and washed it out so its definatley all clear but water is still building up in the fan area below the heater its filling up the water container but still finding its way across somehow.!
