Creda TCR2
  • #51022
    Machine not heating. Checked rear stat pair and heater, all OK. Found another stat mounted high up at the front, also reading short circuit. What else should I check? The dryer will also need the later type door latch as it now only runs when you hold the door shut and has been jumping open during use.
    #306638
    Madmac
    Re: Creda TCR2
    Quite often the timer gives this fault Phidom, had it a couple of times with Indesit group stuff.Had a Hotpoint a few weeks ago with no drum movement, after checking cap, motor & wiring was running out of ideas, tapped timer with screwdriver handle & off she went 😯
    #306639
    Re: Creda TCR2
    Timer ordered, thanks. :tup:
    #306640
    Re: Creda TCR2
    I fitted the new type door latch kit but customer says door still keeps opening by itself. Any suggestions (ones not involving skips, rubbish dumps etc. preferred)?
    #306641
    HotDog
    Re: Creda TCR2
    have never had a problem you cant fit them wrong so is the door twisted failing that i would try another latch kit did you fit latch and springlatch assy
    #306642
    Re: Creda TCR2
    Got one of these with door which has to be held shut with tape. Latch itself, on the door, looks fine. What’s behind the front panel?
    Mike.
    #306643
    suedehead1
    Re: Creda TCR2
    you just get a new latch kit C00257618 comes with the catch and part for front panel change both parts.
    #306644
    Re: Creda TCR2
    Thanks suede. Dunno why I couldn’t find that myself.
    Mike.
