Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Creda TCR2 Belt Change
- This topic has 10 replies, 5 voices, and was last updated 17 years, 4 months ago by
spanner51.
November 17, 2008 at 8:24 pm #41106
spanner51
ParticipantHello
I did my first ever belt change on this condenser dryer, the only thing is, it took me 2 hours. After getting the belt around the drum, I struggled to get it on the motor shaft, past the front fan, and over the static pulley wheel.Has any one any suggestions to speed up this repair for the next time. Thanks in advance
November 17, 2008 at 8:32 pm #268821Penguin45
ParticipantRe: Creda TCR2 Belt Change
Take rear fan off. Undo four motor screws. Roll motor round, fit belt. Use big screwdriver through motor tie bolt to lever it back and refit screws.
November 17, 2008 at 8:39 pm #268822spanner51
Thanks for the quick reply Chris. Now I know that, it seems so obvious. I will remember for next time.
Graham
November 17, 2008 at 8:43 pm #268823helo_75
Participanti dont do it like that
i just pull out drum, put belt over motor shaft, put belt in right position, and put the drum back in, makin sure the belt goes over tension pulley
less than 10 mins
November 17, 2008 at 9:56 pm #268824Penguin45
We’re not all as big and strong and manly as you, Rob……
😆:p45:
November 17, 2008 at 10:17 pm #268825boselecta
ParticipantTake drum bearing off, feed belt around drum, take front fan off, feed belt around it, take 2 jockey roller bolts off, put the rear bolt on and use a screwdriver to tension the belt around it and fit the front screw in. 15 min job.
November 17, 2008 at 11:13 pm #268826iadom
ModeratorRe: Creda TCR2 Belt Change
There is a huge thread HERE on this very subject with all manner of solutions, its whatever floats your boat. I have used the drum slotted into the belt at the side of the machine then swung the drum back into place as well as the old hacksaw frame and using the old belt.
Using the drum to pull the belt on is my preferred method, and I’m not big and strong……. 😉
November 18, 2008 at 12:20 am #268827helo_75
Participantsee, so im not on my own
but the hotpoint manual tells you to do it the penguin way…
everyone will find a way they find easier
November 18, 2008 at 6:53 pm #268828spanner51
Thanks for the input guys
I’m amazed the you can do it so quick
helo 75 10mins
boselecta 15minsI definately need more practise
Graham
November 18, 2008 at 7:52 pm #268829helo_75
Participantitll come mate
ive fitted rakes of them, i work for comet
November 18, 2008 at 8:10 pm #268830boselecta
Participantme too, working for comet I fitted hundreds, like all these jobs the first time you end up stripping the entire thing until you find the best way.
