Creda TCR2 Dryer no heat
  • #73864
    robbra
    Heater stats and front stat ok. At the heater joint block three live and no neutral so no heat. I suspect the timer but as not had a timer go before don’t want to jump in. Any advice welcome.
    Rob
    #389115
    suedehead1
    Re: Creda TCR2 Dryer no heat
    i have had to change the timer before for the same fault.
    #389116
    robbra
    Thanks,
    Just what I needed to know.
    I’ll order it.
    Rob
    #389117
    robbra
    Had a wiring diagram and it was a burnt out float switch. Would not have thought of this causing no heat.
    Thanks Jim
    #389118
    johnnyj
    Why not the circuit goes through the float switch, when the chamber is full the switch breaks and breaks the circuit to the heater.
    #389119
    robbra
    Because I wasn’t aware of that Johnny
