Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › creda tcr2/keeps stopping
- This topic has 17 replies, 7 voices, and was last updated 18 years, 7 months ago by
harley.
August 17, 2007 at 8:46 pm #29871
harley
Participantright where do i start.iwas called to said tumble dryer this week,customer said there was no drum rotation.simple enough i thought.off came the lid and side panel,one nackered capacitor.replaced it and away it went job done.5 miles down the road customer phones to say its not heating,back we go and find one shot device was open circuit should have checked for heat b4 i left it,new thermostat kit(c00116598) fitted heating problem sorted anyway it transpirers that the dryer now keeps stopping or should i say the drum stops rotating after about 15-20 minutes but the pump is still running.filter in door clear,water container ok,condencerunit spotless,leave it for a while and it’ll restart only to cut out again after a period of time.any sugestions (polite ones of course).
frustrated! 😡
August 17, 2007 at 8:56 pm #224989Penguin45
ParticipantRe: creda tcr2/keeps stopping
Start/run relay in the control panel?
August 17, 2007 at 8:57 pm #224990bazza500
relay in behind the control panel is my guess. Had quite a few of these go intermittent.
August 17, 2007 at 8:57 pm #224991bazza500
Damn you penguin, you beat me by seconds!!! 😈
August 17, 2007 at 9:09 pm #224992Penguin45
:waving:
:p45:
August 17, 2007 at 9:15 pm #224993harley
thanks for the help guys,anyone got a part no,cant find any thing on spareslink under the model number or is it past my bedtime
August 17, 2007 at 9:35 pm #224994Penguin45
1702980 I *think*……..
August 17, 2007 at 9:57 pm #224995eastlmark
ModeratorRe: creda tcr2/keeps stopping
1703616 is shown as a ‘relay and led’ its not got the more traditional relay or that one.
August 18, 2007 at 5:49 am #224996bobokines
If the relay/control unit was faulty, surely the whole appliance would die and not come back on until it was started again.
I would go for the thermal overload in the motor… Did you fit the correct rating capacitor? 7uF I think…
BobAugust 18, 2007 at 11:38 am #224997harley
HI BOB,CAPACITOR REPLACEMENT WAS 8UF WHICH IN THEORY SHOULD BE PERFECTLY OK
August 18, 2007 at 11:53 am #224998harley
haveing checked availability,would’nt you know it,masterpart,seme and spareslink only do the relay as a special order,what a pain.
August 18, 2007 at 5:46 pm #224999harley
GUYS,TO CUT A LONG STORY SHORT IT TURNS OUT I HAVE A THREE MONTH OLD TCR2 IN THE GARAGE WHICH I FORGOT I HAD,ANYWAY A FEW OF YOU MENTIONED A RELAY,I HATE TO SAY THIS BUT HAVING STRIPPED MINE DOWN I CAN HONESTLY SAY THERE’S NO RELAY FITTED TO THIS MODEL.SO I’LL HAVE TO GO WITH BOB’S IDEA OF THE MOTOR OVERLOAD OR CONSIDER POSSIBLE TIMER FAULT.ILL LET YOU KNOW HOW I GET ON.
CHEERS, JOHN
August 18, 2007 at 7:41 pm #225000eastlmark
harley wrote:GUYS,TO CUT A LONG STORY SHORT IT TURNS OUT I HAVE A THREE MONTH OLD TCR2 IN THE GARAGE WHICH I FORGOT I HAD, CHEERS, JOHN
…as you do!Think the relay is on the board behind the console, isnt it? not saying that is your problem though.
August 18, 2007 at 8:05 pm #225001leavemetogetonwithit
If it’s the big Schrack relay RM505730 240v 16A then I get them from http://www.rswww.com for about £7 each. Normally in stock. Free delivery by DHL included!
Mike.August 19, 2007 at 10:21 am #225002helo_75
Participantif its only 3 months old, the relay is part of the door lock…
its classed as a bitron door lock, if you look on partfinder, there is 2 listed, depending on SERIAL number
so there is a relay on either model, depends how old it is
if u wanna check, if you try and start dryer with door open, if it buzzes, the relay is in the lock!
not that it matters, cos the fault you got is common.. its the timer thats faulty.. theres a burned contact , so the machine wont tumble after a while
fitted loads of em, worst dryer on market!!
