Creda TCR2 Rubber Impeller
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Creda TCR2 Rubber Impeller
  • #61600
    codlets
    Hi, Does Anyone know where this small rubber impeller can be purchased from ?
    #346763
    washtronics
    Re: Creda TCR2 Rubber Impeller
    it is only available as a complete pump, the impellor is not listed as a spare part by indesit co
    #346764
    timdowning
    About 6 months ago, when I was out of stock of the pumps, I cut a piece of pressure tube to the same length as the impellor. I put a small hole through it so as it was a tight fit for the shaft to push through.
    It worked a treat and still is. The customer said she will call me when it stops pumping again.
    WARNING : THIS IS NOT AN OFFICIAL MODIFICATION. 😉
    #346765
    codlets
    Cheers guys. The modification option sounds like the best one to me, I’ll give that a go thanks !
    #346766
    for £17 is it worth messing around?
