Re: Creda TCR2 Tumble Drier – short circuit?
Usually caused by a failure to keep the condensor clean as advised in the user manual. This allows the back of the condensor chamber to get gunged up and then water gets sprayed onto the elements.
Remove the condensor and clean it out, best way is to blast it through with a pressure hose or an outside tap if you have one.
Lie down on the floor and reach right back into the condensor chamber and pull out any gunge that is clogging the channel along the back.
Remove the small back panel screws, lift the panel back gently and dry out the heater and stats with a hairdryer.
