CREDA Tumble Dryer
  • #56921
    cornflakes
    Model T620CW
    s/n 94105702
    call no heat reported…TOC green spot open circuit
    fitted replacement set of TOC’s
    run to test all ok
    Client rings an hour later..had used for 20 mins..no heat
    returned..checked TOC..green spot open circuit
    the only thing i can find the may be the problem was a blocked filter
    is there any thing else i need to check before i replace TOC;s
    thanks
    Graham
    #329277
    Re: CREDA Tumble Dryer
    Might be worth checking to ensure the air inlet fan hasn’t sucked in dust and muck at the front inlet? Timers are a caution too if the heat switch contacts are welded together, check that the heat switches off on cool down?
