Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Creda Tumble Dryer 37753E Help 3 wires off timer
- This topic has 6 replies, 2 voices, and was last updated 20 years, 3 months ago by
Bernie.
January 3, 2006 at 5:54 pm #14481
Bernie
ParticipantPlease help I have pulled 3 wires off the timer on this Creda T/D 37753E
Changing the jockey pulleys & belt.Has anybody got the wiring diagram or timer connections?
1st call after holidays. Have got wiring diagrams for lots of other machines but not this one!
Bernie
January 3, 2006 at 9:00 pm #159611iadom
ModeratorRe: Creda Tumble Dryer 37753E Help 3 wires off timer
Same timer, 1701221 fits Hotpoint TL71 if thats any help. I don’t have a manual for that model. How did you manage to get wires off the timer doing a belt/pulley change. I tip these upside down and just remove the small lower front panel, then pull the front panel forward to allow the belt to slip round the drum. Never touch the facia or even remove the top to change belt.
January 3, 2006 at 9:38 pm #159612Bernie
ParticipantRe: Creda Tumble Dryer 37753E Help 3 wires off timer
I took the front panel off, wiring loom connected to side of panel.
I normally just take the lower panel off. as you suggested
Don’t know why, must be one of those senior moments.
Thanks for info will look to see if I have HP manual
Bernie
January 3, 2006 at 10:35 pm #159613Bernie
Still need help. Did not have HP TL71 manual either
Bernie
January 3, 2006 at 11:50 pm #159614iadom
Sorry, I may have misled you the actual timer in your machine is a 1701221, the Hotpoint model it also fits is a TL71.
January 9, 2006 at 9:23 am #159615Bernie
Now have service manual for this machine, so if any body need the wiring diagram just let me know
Thanks for the help on this one
Just knowing that there is some were to go to get help if you need to is reassuring.
Thanks again
BernieJanuary 9, 2006 at 10:09 am #159616iadom
Will bear that in mind, I have been to three Creda dryers in past week, unfortunately no 37753’s. I would have noted the connections had I done so.
