creda tumble dryer T601CW
Home Forums Public Support Forums Help And Support Washing Machine Help Forum creda tumble dryer T601CW
  • #48555
    fastcam
    I replaced front thermostat, rear green spot thermostat kit and heater element 2 weeks ago all bought from the sites shop. The machine was working great until 2 days ago. No heat again! Will it be the rear thermostats again? The heater element looks ok. Can anyone shed any light on this. Will i be able to send the thermostats back for replacements.
    thanks in advance
    #296947
    washermanuk
    Re: creda tumble dryer T601CW
    Hi matey 9 times out of ten no heat means the green spot thermostat has tripped and needs replacing?
    most causes are blocked or restricted vent, not keeping filter clean or opening the dryer door before program finishes this may cause machine to overheat ie:last ten mins is the cooling down
    hope this helps?
