Creda tumble dryer T620cw
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Creda tumble dryer T620cw
  • #21010
    fishy
    The drum turns but no heat, I have checked the stats and heater element for continuity and all seem OK. Any ideas.
    #189156
    Re: Creda tumble dryer T620cw
    Did you split the circuit when you checked the stats? You’ll get a back reading through the wiring if you didn’t.
    There is a further thermostat at the front above the door housing.
    Power off at all times, please.
    fishy
    Disconnected the stats and found that the lower one with a green dot on it has failed, do you have a part number that I can order.
    Fishy
    #189158
    http://www.ukwhitegoods.co.uk/modules.p … ucts_id=78
    That’s what you want.
    fishy
    I haver ordered and replaced the stats but it still isn’t heating up. Have checkrd the new stats and all OK. Any ideas?
    Fishy
    #189160
    fishy wrote: Any ideas?
    Yes, the Timer is often the source of this fault 🙁
    Part number 1702509 available by emailing spares@ukwhitegoods.co.uk
