creda w120vw
  • #60987
    stin74
    i bought this off ebay cheap, the bearings have gone.
    is it worth replacing the spider arm when i attempt the bearing replacement, or does it all depend on the condition of the spider. not disasembled it yet to inspect it. anyone done one of these machines ??
    creda w120vw
    #344440
    Re: creda w120vw
    It’s always best to replace the spider at the same time.:wink:
    #344441
    stin74
    Re: creda w120vw
    is it risky not to replace it ?
    #344442
    Re: creda w120vw
    Of course, it’s old, worn and possibly corroded as well, but, you decide! 8)
    #344443
    stin74
    Re: creda w120vw
    Martin wrote:Of course, it’s old, worn and possibly corroded as well, but, you decide! 8)
    i believe the old bearings can be heated up a bit to ease them out, or is it cool them down? do i start from the back bearing first then the inside one ?
    well its the first time ive attempted to change the bearings so fingers crossed 🙂
    #344444
    Re: creda w120vw
    Unless you want to melt the drum or the alloy bearing support collar then you should not go anywhere near it with heat. :rolls:
    If it is really bad then the chances are that the inner bearing will have collpased. Removing whats left of the outer bearing shell is very difficult.
