Creda W200FW
  • #53731
    robbra
    have noisy bearings on this. It has a metal pulley so….
    Is this the non Rubena type bearing kit and is it likely that the shaft will be damaged and need a new spider?
    Rob
    #316990
    Re: Creada W200FW
    If it is a screwed drum then it has the 35mm bearings, the kit to replace it is the rubena one, it may have the earlier type or have the rubena seal in it already depending on age.
    There is no easy way to tell if a new spider is needed unless the drum is really flopping around. I only replace one spider in five bearing changes, really have to ‘suck it and see’.
    robbra
    Re: Creada W200FW
    Thanks Jim,
    Little play but lots of noise, 5 yrs and 3 months. By screwed drum I think you mean WMA type? If so, yes it is.
    Bearing kit to order.
    Rob
    PS. Did I really spell Creda, Creada 😳
    Had a bad day, brakes failed on the van luckily going up a hill 8)
    #316992
    Re: Creada W200FW
    I always take a drum spider with me on any bearing or drum rear half job, just in case it is needed. They are not that expensive to carry as a spare.
