creda w220 fab cond
  • #29196
    wilf
    how do I access machine to test fab con i.e. both valves together to test its working
    wilf
    #222280
    petalpop
    Re: creda w220 fab cond
    put live from other valve to it and put it on a rinse
    #222281
    petalpop wrote:put live from other valve to it and put it on a rinse
    Not if it’s a double integrated valve which they usually are on this model. Also they have small connectors with tabs preventing mixing them up! 😕
    I would rather suggest, having first confirmed reading from both coils and the water pressure is OK, that you set it on a ‘Rinse & Spin Cycle’? 😉
    #222282
    wilf
    cold fill only machine it requires both soilnoids to activate to converge jets for fab cond. on rinse prog only rinse valve only is running I dont want to wait for a whole wash to test this
    wilf
    #222283
    Have sent you diagnostics, should save a bit of time. 😉
