CREDA W220VW CONTROL BOARD CONFIGURATION CODE
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries CREDA W220VW CONTROL BOARD CONFIGURATION CODE
Viewing 15 posts - 1 through 15 (of 21 total)
  • #12733
    mike1
    I AM FITTING A MODULE PART NO. 1604321 (WHICH SUPERCEDES FROM 1604201 ).
    BUT IT DOESNT LIST THE W220VW CONFIGURATION CODE.
    CAN ANYONE PLEASE HELP.
    THANKS
    #151362
    Re: CREDA W220VW CONTROL BOARD CONFIGURATION CODE
    If you PM me your e-mail address, ‘quietly’ 😉 I will see what I can do. 🙂
    Although my Ntl e-mail has been up the spout for the last couple of days, they are having major problems nationwide ATM.
    #151363
    mike1
    i wonder if i have got the correct module.
    electrue say part number 1604201 control module has now changed to 1604321.
    could any body confirm this or are they wrong(perish the thought)
    thanks
    mike
    #151364
    Module should be a 1604769 or a 1605332 for cold fill machines (after date code 41). After date code 29 they reverted back to an earlier version of software. The 1604769 is the replacement for all W220VW machines that are mixed fill.
    E-mail sent. 😉
    #151365
    Dave_Conway
    Masterpart say the same Mike, I think there may be a serial number difference though.
    Can someone check their Partfinder disk please as mine expired with no warning 🙄
    #151366
    Dave_Conway
    :wave:
    #151367
    Dave_Conway wrote:Masterpart say the same Mike, I think there may be a serial number difference though.
    Mine flagged up a warning of impending update about six or seven weeks ago.
    #151368
    Dave_Conway
    Yep, they normally do, no idea why this time though 🙁
    not to worry, another one is on the way 🙂
    #151369
    Dave_Conway wrote:Yep, they normally do, no idea why this time though 🙁
    Taken out a second mortgage then 😥 🙂
    #151370
    Dave_Conway wrote:not to worry, another one is on the way
    I’m sure if we ask Brian nicely, he will give us a UKW group discount on Partfinder 💡
    I hope Dave Hazzard will post mine by return as its 4 days and counting since mine went belly-up and I cannot source the parts I need 🙁
    (Why should that be anyway 🙄 )
    #151371
    Dave_Conway
    Yep 🙁
    Is yours still working Jim ? Only I need the part numbers for the water reservoir chamber cap or the whole chamber if it doesn’t come on it’s own and the fluff filter. Creda 37754
    Thanks.
    #151372
    Dave_Conway
    Martin wrote:I’m sure if we ask Brian nicely, he will give us a UKW group discount on Partfinder 💡
    I’ve asked 😀
    #151373
    I have a new one, issue Five, had it since beginning of September.
    #151374
    Dave_Conway wrote:Yep 🙁
    Thanks.
    Cap is 1701174, filter is 1701130. They have stopped fitting the cap to the container for a long time now, the hole is left completely uncovered. If you forget to remove the container first and tip the machines forward you get a nice flood all over the floor.
    Complete container is a 1701150, that will almost certainly come without a cap.
    Yep, just checked on a TDC 62, same number for container but no cap listed.
    #151375
    Dave_Conway
    Thankyou 😀
