Creda W220VW Diagram
  • #59952
    robstech
    Need diagram to show connections to control module
    Cheers
    Rob
    #340199
    Re: Creda W220VW Diagram
    Split drum or welded drum version?
    #340200
    if you look most connections will only go on 1 position
    look at the pcb and the slots on the plugs
    the only connection that different is the 2 single wires on the right of the timer the wire with the terminal cover goes on the right hand side
    hope this helps
    Sorry, should have mentioned information sent. 😳
    #340202
    robstech
    Thanks everyone for your help, Going back with a board from EMW,
    Rob
