Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Creda W220VW washing machine Fill Problem/s
- This topic has 7 replies, 3 voices, and was last updated 11 years, 2 months ago by
jontymox.
January 10, 2015 at 9:33 pm #83700
jontymox
ParticipantGood evening,
Wondering if anyone can help with an obscure fault on the above w/m?
When a wash programme is selected, all is well… water fills, washes, heats… until first drain has ended.
Then, following an approximate two minute pause, “RUN” & “END” light flash, and no further cycle operation.
I renewed the pressure switch… same problem, and then fitted a re-conditioned control board today… same problem, all well until first drain, then no further water fill, and above lights flashing.
I’ve double checked the wiring connections to, and from the board, and would appreciate some help.
Kind regards,
jonty
January 10, 2015 at 11:13 pm #423494electrofix
ModeratorRe: Creda W220VW washing machine Fill Problem/s
have you checked
water valves
pressure bell
if you restart programme immediatly does it start ?Dave
January 10, 2015 at 11:32 pm #423495iadom
PM me an e mail address and I will send you the manual.
January 12, 2015 at 9:07 pm #423496jontymox
ParticipantRe: Creda W220VW washing machine Fill Problem/s
Thank you electrofix and iadom,
Returned today, and carried out the Test Sequence as per manual.
This confirmed Error Code: 2 – Failure to set pressure switch in 94 seconds.
The pressure chamber is clear, and the p/s hose is fine.
I haven’t tested the water valves yet, as it initially fills perfectly well.
Could e/fix let me know if pressure bell means bellows, as I replaced the p/switch prior to the module/board.
Kind regards,
jonty
January 12, 2015 at 9:28 pm #423497iadom
Pressure chamber=pressure bell. Possibly time to try a fill valve. 😉
January 12, 2015 at 9:41 pm #423498jontymox
Agreed, but I wonder why the m/c initially fills perfectly?
Jon
January 12, 2015 at 10:16 pm #423499iadom
Just a thought, what is the serial number/date code? At date code 42 the machine was changed from a H+C fill to C fill only. There are different programming instructions for the H+C and the C fill machines. It will fill through the rinse valve to start the programme then switch to the hot valve or cold wash valve to give a timed fill for the wash programmes.
If the rinse valve is faulty then you would get the symptoms you describe. It is possible that the valve is failing intermittently. allowing a small amount of water for the initial fill but failing when it gets to the rinse cycle. ❓
January 16, 2015 at 5:30 pm #423500jontymox
Renewed fill valves… cured fault!
Suspect faulty solenoid.
Thanks again folks.
jonty
