Home › Forums › Public Support Forums › International Forums › USA & Territories Appliance Forum › Creda Wall Oven ESO 313 timer/controller issue
- This topic has 20 replies, 2 voices, and was last updated 6 years, 3 months ago by
Mitchell Schwartz.
January 6, 2020 at 3:47 pm #96984
Mitchell Schwartz
ParticipantThe clock/timer is frequently cutting out and the display fades and flickers at a very low light level. I have to press the manual button several times for it to revert to normal, which may last many hours until it happens again. Is this indicative of a faulty timer control, or a fuse or an electrical power issue? If the timer needs to be replaced, how complex is this job, assuming the part is available? I would most likely hire a technician to repair this if possible.
January 6, 2020 at 9:37 pm #465707electrofix
Moderatorwell need more info to look up the cooker as I cant find the model
if its a simple timer then it can be bridged so the oven works without it
January 6, 2020 at 10:45 pm #465708Mitchell Schwartz
ParticipantWhat other info is required? According to the product rating plate the model # is ESO 313 (the manual I have lists model # ESO 310/312). The serial # appears to be 62 E000042
January 6, 2020 at 11:27 pm #465709electrofix
Moderatorwell cant even find that model on google
trie ESO and ES0 both don’t bring up anything on any numberit very old
you can post a pic to try and help
January 6, 2020 at 11:44 pm #465710Mitchell Schwartz
ParticipantThere is file restriction size of 19 KB and my photo is larger much than this. Can the restriction be eliminated or increased a suitable amount to allow me to upload?
January 6, 2020 at 11:47 pm #465711electrofix
ModeratorI have no right to vary the size restriction but
post file on another site and post a public link
January 7, 2020 at 12:27 am #465712electrofix
Moderatorthat makes sense now these early units are known by the 48 number so yours is model 48358
if it was a power issue I would expect it to go on and off while in use
it will be a simple clock and be very easy to bridge it but to able to tell you have I need to see a picture of the rear connections on the clock unit
you could pull the unit out and look at the terminal block and if its plugged into another socket try a 13a extension lead
January 7, 2020 at 1:01 am #465713Mitchell Schwartz
ParticipantOK, but can you provide more detailed info on how remove the unit, and instructions on how to jump the terminals to bypass the timer? I have a technician that can come to do the work, who is at least familiar with these appliances. I can coordinate the work so that we can catch you during work hours. But aside, knowing the model #, do you think a replacement timer is avialable?
January 7, 2020 at 1:58 am #465714electrofix
Moderatorbe a long shot on that one
to get parts info for these ovens have to set my computer back 19 years
unscrew the screws holding oven in housing ( round door )
pull oven out, remove top after first removing power
take some clear pic of the rear of the timer
should be able to work it out from thereDave
January 7, 2020 at 3:32 am #465715Mitchell Schwartz
ParticipantOK, I’ll try to do this and get back to you. Thanks for your help Dave.
January 8, 2020 at 5:11 pm #465716Mitchell Schwartz
ParticipantDave, if I schedule to do this on Friday, are you available to answer us real time? Say around 2-2:30pm UK time?
January 8, 2020 at 11:21 pm #465717electrofix
Moderatorwill do my best to remember but depends how busy I am at work at the time . will only be near a screen till about 3 then I have to go and do calls
January 9, 2020 at 4:14 am #465718Mitchell Schwartz
ParticipantOK,m perhaps I can schedule it a bit earlier on Friday, but to get you the photo by about 2:00pm. Is there another email I can reach you at?
Many thanksJanuary 9, 2020 at 4:36 pm #465719Mitchell Schwartz
ParticipantI should be able to get you a photo before 2pm on Friday. I hope that you will be available to respond around that time. Is there a direct email that we can use?
January 9, 2020 at 7:50 pm #465720electrofix
Moderatordon’t check the email all the time maybe 3 or 4 times a day
will try to think on to set a reminder
