Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Creda washing machine Mod W100FW
- This topic has 11 replies, 7 voices, and was last updated 19 years, 5 months ago by
Ashby.
October 25, 2006 at 8:36 am #21990
Ashby
ParticipantMorning all, Can someone help with a wiring diagram for this machine please? It’s not heating. Element is ok.
AshbyOctober 26, 2006 at 8:47 am #193307eastlmark
ModeratorRe: Creda washing machine Mod W100FW
Dont have a wiring diagram but there is not much between the heater and the timer so i its not the heater, ntc or the wires its got to be the timer.
October 26, 2006 at 9:57 am #193308Martin
ParticipantRe: Creda washing machine Mod W100FW
…..or the ‘Economy’ button has been pressed 😉
October 26, 2006 at 6:03 pm #193309Ashby
Hi Chaps, Thanks for your help. sorted that one. It was the economy button. However, it’s now on the rinse cycle and surges into a spin rather than a tumble.I’ve checked motor plug for loose connections and where it goes to the board. That all seems ok. Haven’t checked brushes yet. any other ideas? most gratefull. Thanks.
AshbyOctober 26, 2006 at 6:14 pm #193310Bryan
Ashby wrote: However, it’s now on the rinse cycle and surges into a spin rather than a tumble.
These new models do that as a feature , so probably still nothing actually wrong with machine. If sump trap etc. partially blocked it`ll throw water back out the soap dispenser drawer at the rinse stage you describe.
HTH
Bryan
October 26, 2006 at 6:26 pm #193311Ashby
Thanks Bryan, but the machine has never done this before. After it has filled for the rinse, it surges into spin and throws the machine across the floor.Strange?
Ashby.October 27, 2006 at 6:18 pm #193312Ashby
Hi, I’m still having problems with this machine. after filling for a rinse instead of going into a distribute it does a very fast spin knocking the machine around the floor. it does this a couple of times then stops. I’ve had the board checked. That’s ok. checked for loose wiring, the motor is ok too. I’m Baffled. Anyone else had the same problem?
Ashby. 😥October 27, 2006 at 10:36 pm #193313iadom
Has it got an FHP motor, if so check that the tacho magnet has not come loose. you need to prise off the metal disc to see it. Easy to refit.
October 28, 2006 at 7:45 am #193314Ashby
Thanks Jim, I did check the tacho with multimeter, that was ok. I didn’t take it apart though. I’ll do that monday.
Much appreciated.
Ashby (it is FHP motor)October 28, 2006 at 9:33 am #193315PGS
Your gonna have to fit a motor im afraid.
October 28, 2006 at 5:01 pm #193316roy1
ParticipantI hav re-fitted the FHP tacho magnet removing the
disc ,turning the magnet over and re-fitting with
superglue never been back to one .
RoyOctober 28, 2006 at 6:54 pm #193317Ashby
Hi, Thanks PGS and Roy1, The customer rang today and said she’s been and bought a new machine.
Thanks.
Ashby -
