Not having much luck the last few days, washing machine playing up nd now this 🙁
I was using the oven last night and it suddenly tripped the main house switch, when i tried to put the oven back on later on the fan is running but there is no heat coming from it.
Main oven element is the likely culprit. Switch off at the mains and remove the inner back panel. In most cases the element will have visible signs of damage.
One of the easier elements to change, can be obtained from spares@ukwhitegoods.co.uk. Or follow this link.
